June 07, 2026, 04:17:42 am
Added a Juki to the Family
Started by Mojo, August 10, 2011, 07:40:31 pm
VeI've got a " N" model I've used some singer parts on it
It will take larger bobbing  u and m I think the m was bigest
I'm. Just used to the g bobbins with my singer
Quote from: Gregg @ Keystone Sewing on August 11, 2011, 10:03:26 am
Now I think about it, I DO remember seeing some of the honey color N models.  Again, I haven't seen hundreds of these N models flying around.  The white are the newer ones, but again, I think I remember the white ones being the ones showing up with out of the box problems.
Were the white ones Japanese made or Chinese made ? Or are all the Juki's made in Japan ? I know my N model is Japanese made but was wondering about the rest.
I've got a 263N that's white it's tag says made in Japan also
Hello,
I have a Juki L-562. Now, I know what you L-563 guys are thinking, but it's not the size of the bobbin that counts, it's what you can do with it.  ;D
I oil my machine each time I sit down to sew. I oil all the red holes.
Do I need to ever oil anything under the machine? My manual indicates places to oil underneath but it doesn't seem to make sense to me.
Thank you,
Quote from: gene on August 11, 2011, 05:56:52 pm
Thank you,
Yes, of course you do.  Hook, hook driving gear, anything that looks like it moves.  Some oil holes down there, too.  Also open up the face plate cover, as well, and do the same.
Thanks Gregg, I'm glad I asked. And I will take the time to figure it out and oil away.
I think that I assumed that since I didn't fully understand the diagram, it must not be important. Wow. How many times does this faulty logic cause problems?
Hey Gene, did you ever solve that "gathering" problem?
Oil every four hours of use or if machine has sat idle for some time.
All Lu 563 are made in Japan, as well as 1508 and 1541 series.  Some juki are made in China today, all are clearly marked as to country of manufacture.
christwo
Not that it is relevant to anything but just curious, Greg do you know how much the 562 weighs? I seen in the features page for the 280L its gross weight is 35.2 kg (about 78 pounds) and I just wanted to know how the 562 compares but cannot find its weight in the owners manual.
They all weight alot. Enough to give you a hernia anyways...:)
It is going to be close to 48 KG. The newer 1508 weighs 48 kg and that is the later 563 model.
christwo
August 12, 2011, 11:09:35 am #25 Last Edit: August 12, 2011, 11:12:05 am by christwo
Oh boy! lol. Yeah I wondered just because I always was curious how much it weighed after having to carry it about 200 feet from the car to my shop! Wow that is significantly lighter then the Nakajima 280L (DNU-241 as well I imagine)
I never weighed them, but I've toted them, and I would guess that my 1508 head weighs almost twice as much as my old 562 head .
I can't carry the head for my 1541-N-7.  I could handle the 562, but I won't even attempt to move the 1541 alone.
BigJohn
August 12, 2011, 01:42:25 pm #28 Last Edit: August 12, 2011, 01:43:59 pm by BigJohn
Chris looks to me like you did good!
Sofadoc,
My gathering problem appears to be caused by running too light a fabric on the machine. When I hand turn the wheel, the foot that goes up in the air and then comes back toward the operator pulls the thread back toward the operator a bit, and this causes the fabric to be pulled back toward the walking foot.
On thicker fabric, vinyl, or leather, I can see the thread tighten, but the fabric does not pull back with the foot.
My other machine, a Zoje 8500, which is the same as a Juki 8500 straight stitch, I can sew leather and silk with no problem, just a bit of changing the thread tension. Occasionally I will need to use a thinner needle and thinner thread.
