February 14, 2026, 05:14:34 am
duct tape glue on boat cover
Started by cthomps, August 05, 2011, 05:47:22 am
cthomps
Good morning.  I just took in a small canvas boat cover for restitch.  The guy was in Canada when it all pulled apart.  He duct taped all the seams together, which in turn were exposed to the sun on the trip back.  Is there any way to remove the sticky stuff?  I haven't removed the tape yet, but there is alot of it, and I'm not sure if I will be able to sew through the glue it if I do.  Thanks Carol
SHHR
I just repaired a bad install on a convertible top for a kid with an "expert" friend who thought he could do it. As a result the top looked horrible and leaked even worse. Anyway the kid must've been related to Red Green because he sealed all around the top with duct tape to keep the water out. It left a terrible residue on it.
I started cleaning it with mineral spirits with decent results. The mineral spirits won't melt the polyester material like laquer thinner would. While at Lowe's I saw a product called Goof Off located in the paint department and that took the glue off even better with no damage to the material. What ever you use just test a small area first to see if it affects the material.
Kyle
needles eye
cthomps
Thanks.  I happen to have both of your suggestions on hand.  Just wondering if they sell it in gallons? :D
WD-40 or Goo Gone ( Goo off ).
If that doesn't work, set it on fire. :)
August 05, 2011, 02:50:45 pm #5 Last Edit: August 05, 2011, 02:52:11 pm by Peppy
When I'm trying to strip or loosen gunk or whatever, I put paper towels on it then saturate them with my solvent and cover it with plastic to stop it from evaporating. Then you can let it soften up before you attack it.
But I like Mojo's suggestion-
http://youtu.be/Dyh5v_GizaY
I learned when I first started cleaning the four factors of cleaning - TACT
T - Time, dwell time of the cleaner on the area,
A - Agitation, elbow grease in rubbing or scrubbing
C - Chemical, get the right cleaner for the stain / soiling / residue
T -  Temperature, usually the warmer, the better
The first rule is the less of one of these, the more you need of the others to get the same results.
I'd go with a strong solvent and less agitation.
Goo-Gone and Goof-Off are quite different products, though often confused.   Goof-Off is quite a bit stronger.
Hydrocarbon solvency is measured by K-B (Kauri-Butanol) value.   Mineral spirits is quite low, the solvents in Goof-Off a bit higher.   While it really requires testing prior to use, I've souped up a solvent mix by adding about 1 part lacquer thinner to 4 parts mineral spirits.   I cannot caution enough to test this prior to use, especially if you are going to let it sit a while to soften up the goo (the first "T").
http://en.wikipedia.org/wiki/Kauri-butanol
