February 10, 2026, 11:47:51 pm
Awning guys help!
Started by kat, July 20, 2011, 07:31:43 pm
kat
I have successfully redone the awnings on our motor home..yaaa!
So my wonderful other half brought home an awning from a car trailer that needed a repair that I did ok but.......I need to put the welt cord in and I did not mesure the distance between the front two cords (it has a flap that hangs over the front so one cord is at the flap and the other is behind that to holds it snugly onto the roll)...is the size standard between the two cords. I cant measure his as its about 2 hours away.
BigJohn
Many factory made replacements are made in two pieces now, the ruffle is a total separate piece as that allows it to be installed on any size roller!
kat
July 20, 2011, 07:59:27 pm #2 Last Edit: July 20, 2011, 08:07:03 pm by kat
So you are saying I could Just cut the flap off and put the cord on the very end of the main awning and then just slide the flap part in its hole and it will all roll up ok?
ok found this pic....i think it will work
Allan
Kat
On my awning it was 90mm between the two but I would try another van in your area and check
Just go to a local caravan park.  I am sure there will be someone there that will let you measure their awning
Allan
BigJohn
Kat:
     Glad my information helped you, I've seen several of these two piece units installed! Another thing to mention the two piece design allows you to cut the old awning off and then install the two pieces, if holes don't exist for both pieces just drill and file for them.
